メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
My 2011 iMac 27" does not boot after randomly restarting.
My iMac 27” has been randomly restarting and kernel panicking for a week, as well as getting hotter.
It boots on an external ssd connected to one of the thunderbolts ports since the internal drive died.
Now, after a final restart, it does not boot anymore : the external drive’s led lights up, the fans rotate the cpu seems to warm up, but no chime and the display remains black. I also checked on the network and with Remote Desktop : nada. I.e. the Mac does not boot.
I’m thinking power supply or graphic card… I did a hardware test last week and there was no problem ;except for the internal HD.
Any insight ?
Thanks
Sergeï
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Observe the diagnostic LEDs on the logic board. If just #1 is lit, change the power supply. If 3 LEDs are lit, go for the video board.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Thank you for the info Mayer.
How should I do that ? Do I open the iMac and then plug it in in and start without the display ? And where are those leds ?
Thanks
さんによる
OK Thank you ! In. the meantime, I resetted the SMC and the iMac boots again... Currently running an extended hardware test.
さんによる
コメントを追加
回答を追加する
gl0uk さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 56
