Paas word Reset instructions
The log in password has been forgotten and I need to reset the pc.
If you made one already then you are very lucky and the following steps can easily reset your Toshiba laptop password with that disk:
Step 1: Plug in the password-reset disk and reboot your laptop. When the welcome screen appears, simply click on "Reset Password…" located right under empty password field.
Step 2: A new password reset wizard will open, click on "Next" once. Choose the driver where the password reset disk is situated. Setup a new password and click on "next".
Step 3: Finish the setup wizard and restart your computer. Now, simply enter the new password when asked and you will be able to enter into your laptop normally.
A kindly remind: The password-reset disk can be only used to reset password on the computer that created the reset disk. It can't reset password on other computers.
If you are unlucky to not make a disk, you may try to make a fresh installation of your Windows.
A quick reminder: You’d better back up your computer before any reset or re-installation.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 304
