メインコンテンツにスキップ
家庭用から車のオーディオシステム、計算機など幅広いエレクトロニクスギアの修理ガイド
26451回答 すべてを表示
Phone fell in water
So i droped my phone in water and its honor play there was no sound and there was headphone icon so i grabed that thing you clean your ears and cleaned headphone jack and there was red paint/liquid on it is it really bad phone works like it worked before
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
@onespray let us know the exact make and model of your phone
さんによる
its honor play
さんによる
コメントを追加
2件の回答
ベストアンサー
@onespray the very first thing you want to do is to not try to restart the phone. This may further damage your phone. You also do not want to try to charge it any further. The next thing to do is to clean it. Completely disassemble your phone. Once it is disassembled, you do need to clean it properly. You will need high grade isopropyl alcohol and a soft brush. Use this guide to see how to clean it. Even so it was written for an apple iPhone 3G all the points are still pertinent to your phone. While you are cleaning it, check for any broken, missing or burned looking components. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Once all this is done, reassemble your phone and reevaluate. It is most likely that all of your symptoms are only related to corrosion and short circuits.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
最も参考になった回答
The trouble with water damage is it can seem like your device is fine and then one day it just stops working. Even if it is working now until it is properly cleaned the corrosion will continue. It is possible that there is no internal water damage or at least minimal but the best way to be sure is to open the device (if your comfortable doing that) and inspect for corrosion/water damage. If corrosion is found your best bet would be to have it serviced for water damage at a local repair shop. Make sure they know what they are doing, all the shields need to be removed from the motherboard and it needs to be put in an ultrasonic cleaner. Any damaged components would need to be replaced which may require microsoldering.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
After 24hours it doesnt charge and makes some kinda beeping noise but hwn its turned off id shows charging indicator starts to beeep for like 10s turns off and agains that indicator
さんによる
コメントを追加
回答を追加する
Eimantas Stregauskas さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 64
