メインコンテンツにスキップ
Samsung Galaxy S8 Activeは、モデルナンバーSM-G892A(AT&T)、SM-G892U(T-Mobile/Sprint)で識別され、2017年8月に発売されました。Samsung Galaxy S8 Activeは、サムスン電子が第8弾として生産したAndroidスマートフォンです。
screwed up replacement front screen Galaxy S8
Please help I’ve screwed up somewhere.
Objective to change front screen which had a slight crack.
What I did.
Heated screen to soften adhesive. Started at top right corner got glass to lift so slid down long edge and put spacer to hold corner open worked around and removed screen. put new adhesive in order top,bottom, right and left. noticed new screen clear not smoked so gently warmed adhesive replaced screen realized I had a silver colored screen not black powered on nothing pressed down key and power key unti phone vibrated only thing that happened was got couple of lit pixels blue in top left corner and green about 6 picels to right on same level. these then went out and seems power off. Checked charge state with charger seems full .
So the BIG question of the day is “ What have I done wrong “ - anyone any ideas how to fix please.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Many thanks
Wil go see alibaba.
Keith
さんによる
コメントを追加
1 件の回答
ベストアンサー
You've split the screen in 2… look at the back of the glass uve removed part of the screen will probably still be in there hence the silver part of the screen showing. U will have to replace the complete screen.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keith Bouckley さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 9
今までの合計 162
