メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
Why is my wifi grayed out?
Hey, I have an iphone 8 plus that has wifi grayed out, but will still connect to cellular. Any ideas? I have already reset it entirely and it still didn’t work.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
4件の回答
ベストアンサー
Broken wifi chip which requires board level repair, that’s it.
Wifi and cellular are unrelated.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Why can't it be the wifi antenna?
さんによる
It’s definitely not the antenna, the logic function is not working, so it’s a chip issue.
It’s like when your car won’t start, but you are suspecting there is something wrong with the tire.
さんによる
If the antenna is “broken” (common with iPhone 6), you get very low signal. When the WiFi function altogether is missing, then the wifi circuit is down. A lot of times from drop damage (common with iPhone 7), sometimes from electrical damage (common with iPhone 6s).
さんによる
I had same issue, ended up being a software issue, I noticed also at the same time I had a greyed out wifi, my phone. Would randomly not charge, this to was fixed with my new software
さんによる
Hi, im 16. How do i know what the problem is? Wether if its the antenna or the board? The Wi-Fi is greyed out, I don't have cellular data, and I'm trying to repair myself. What should I do?
さんによる
1以上のコメントを表示
コメントを追加
That sounds like WI-FI chip is damaged or dry soldered.There have two factor that you can solve by this way.
Sometime WI-FI chip dry soldered throw over heat that remove PCB from board and re-hot WI-FI chip on 240 aprox 1 min then check most of the cases are solved.If the problem is still same remove the WI-FI chip then re-ball and fix.
If you have to change the WI-FI chip that need to unbind the Nand chip too.So,you need the Nand programmer to unbind WI-FI address or WI-FI address unlocked.If you have to know further this may help you.Have all process 7,7Plus and 8,8Plus have same process.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Sounds like you are having issues with your wifi antenna. Your in good luck it’s really cheap.
iPhone 8 Plus Wi-Fi Diversity Antenna
Replace the Wi-Fi antenna and cable that is adhered to the loudspeaker in the lower right corner inside the rear case compatible with the iPhone 8 Plus model #A1864, A1897, A1898.の画像
製品
$11.99
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
It's rarely the WiFi antenna. Besides, even if you remove the antenna, you'll still get one or no bars but the function will not be grayed out.
さんによる
If the antenna is “broken,” you get very low signal. When the WiFi function altogether is missing, then the wifi circuit is down. A lot of times from drop damage (common with iPhone 7), sometimes from electrical damage (common with iPhone 6s).
さんによる
What you are saying is, the TV is not turning on, it is probably the antenna that needs replacing.
さんによる
Thanks for all the help @tomchai @rany @refectio
さんによる
コメントを追加
Can confirm it is board related. Have ran into this issue and it was still occurring after replacing all antennas.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Philip Doherty さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 20
今までの合計 11,053
