メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
After fixed iPhone 7 audio IC, the phone won’t charge
Hi guys, I have an iPhone 7 here. It has classic audio IC problem: Grey-out speaker and takes ages to load. As usual I removed the big audio chip, did the jumpers, installed the IC, then I started to notice something is not right: the phone is warm and took ages to load, the system is very laggard, and the phone wouldn’t charge. I disconnected the charging flex from motherboard, then the phone was back to normal, the phone was quick to start and everything seems working properly with the charging flex disconnected. I tried two new charging flexes, same thing happened. As soon as I connected the charging flex, the phone was warm and slow to start.
Because the phone worked fine before I did the audio IC repair. I thought somewhere is shorted under the audio IC. So I removed the big audio chip, however the pads looked fine. Nothing is shorted under the chip. I installed the audio IC back to the board. Again same thing happened. The phone is warm and slow as soon as I connected the charging flex. The phone would work fine with charging flex disconnected.
I want to ask, does the audio IC has anything to do with the charging flex? I checked the components around the charging connector. They all look good. None of them was disturbed.
Thanks in advance for any suggestions.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
3 件のコメント
Have you tried a known good battery? I have never run into charging issues after audio ic repair.
さんによる
Yes I tried new battery, new charging flex. As soon as I connected the charging flex, the phone was warm and system was very slow, not charging is just one of the symptoms. The phone works properly without the charging flex connected. Something must be shorted when connecting the charging flex, but I don’t know where.
さんによる
Hey guys im having the exact same problem with 2 iphone 7. I have done like 90 iphone sounc ic and never had this issue, what was the solution?
さんによる
コメントを追加
3件の回答
ベストアンサー
The Audio IC does communicate to the lower microphones, speaker and the charge port for the headphones so in a sense, it does have something to do with the Charge Port.
Have you tried to use a different charge port, just to eliminate that possibility?
Obviously something went askew during the repair and realistically, it should be in the Audio IC area (or on the flip side of the board). I would start checking the main power rails that feed the Audio IC as well as the main output lines and compare to a known-good device.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Charging flex is not only for charging that stands for various supportive component for output or input.Check the all pin of the dock connector on motherboard there you got solution.Which section is heat up find first.Lower mic and charging related component and vibration related circuit check.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Change the audio ic for another it migth be bad.
Sometimes if the cellphone is not turned on and you connect battery you are going to fell warm on the counter side of audio ic, after audio ic replacement.
So just change for another ic
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
phonestore.uk さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 5
過去 30 日: 10
今までの合計 1,789
