メインコンテンツにスキップ
2014年9月19日に発売されました。この5.5インチサイズのスクリーンをもつiPhoneは、iPhone6の拡大サイズ版です。
1525回答 すべてを表示
iPhone 6 Plus Error 4013 after Screen, Logic, and Lightning replaced
I recently gained possession of an iPhone 6 Plus that I replaced the screen on for a friend. The phone then proceeded to boot loop until it ran out of power. Thinking that the device was fubar, he gave it to me. So I decided to try basically everything. Got to the point that I decided to replace the logic board after having heard that error 4013 can be NAND related. Did that. Still get the exact same error whenever I try to restore it with iTunes.
64GB AT&T Locked iPhone 6 Plus
Parts replaced:
  • Screen
  • Lightning and audio assembly
  • Logic Board
  • 5GHz wireless antenna
Any insight?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
disconnect everything except chargeport and see if it will flash without errors, then if it goes through ok start connecting each component one at a time until you find the culprit.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
well... seems like the screen was the problem, but that raises a new question... how come a screen that was purchased from iFixit didn't let the phone boot or restore...
さんによる
So, that "fixed" it, but now it just boot loops forever again... And I can't test the original screen anymore because it was practically unusable when I replaced it.
さんによる
Bad front camera or home button flex from a screen that has preassembled components can cause this.
さんによる
コメントを追加
That is Nand issues,Most of the cases you have to reprogram Nand with removing from logic board and reprogram with programmer.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The logic board has already been replaced with a known good board. So the issue is no longer NAND related. Also, I was able to get it restored by taking the replaced screen off. So the issue is now with the screen and that it causes a boot loop whenever it’s connected.
さんによる
コメントを追加
回答を追加する
John Peters さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 74
