メインコンテンツにスキップ
Thin, light and powerful with incredible sound and Wi-Fi capabilities is what everyone needs to have on the go.
Is it difficult to change the charging port?
So i have to hold the cable in a specific angle for the laptop to load. Should mean, that the charging port needs an exchange. Not i dont have any special equipment apart from screwdrivers. Is it difficult to exchange that part?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
First you should try using a different charger. If that doesn’t work then you should go ahead and change the charging port. Its shouldn’t be a hard job it just takes patients and time.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
do you think the charger may cause the problem? If it were the issue, then shouldnt it either be working or not working, regardless of wether i have to permanently keep it pushed to the top side of the charge port
さんによる
No it can be a loos wire in the charger. But there is still a chance that it's the charging port. I recommend you first buy a charger with returns just in case.
さんによる
コメントを追加
回答を追加する
dj-paok さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 202
