メインコンテンツにスキップ
WiFi range suddenly got worse
My laptop can not connect to wireless network only when it's placed next to a router, it doesn't work when it's 15 metres away. I have same issues when I boot up Ubuntu USB. What exact parts should I buy so they'll be compatible with my laptop?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
i can not connect to the internet and the problem is that the connection betweenmy access point,router or cable modem and the internet is broken…how can i fix it?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi Vikror, I would suggest you to check on your wifi card that was installed inside your mainboard.
Sometimes due to impact, the wifi pigtail cable which is connected to the antenna  might come out.
Check if it is properly connected to it.
If it is connected well, consider updating the wifi card driver to the latest version first.
If it does not work and you have a spare card, install it to try, while observing the results.
If the replacement card is still having issues, you might have an issues with the laptop internal antenna.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thank you for response.
It looks like one of antenna cables is broken where it goes through a hinge.
さんによる
Hi Viktor, try splicing it and see if it works. else you need to get those cable replacement.
さんによる
コメントを追加
回答を追加する
Viktor さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 8
今までの合計 171
