メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Logic board getting hot
Dropped iphone 8 on its bottom right corner (looking at the screen). Screen did not work afterwards, and upon plugging into a power source, phone was getting hot, but not responding to any of my clicks or touches. Eventually it stopped generating heat when i plugged it in.
Talked to Apple Genius, told me the battery is at fault but claimed all other components should be fine. So i undertook the task of replacing the battery as well as the LCD/digitizer myself.
Using the new battery and screen, when i plug into a power source, i get heating issue again, this time with the phone opened up i can feel the source, and it gets generated on the logic board, just south of the rear facing camera (near/on A11 chip). Screen still does not work, new battery does not get hot, Could the logic board be at fault here? Is there a potential short? Can i still somehoe recover my data?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
First detach the camera flex and back camera connector from logic board and check.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It is quite common if a phone is getting hot, that there is a short circuit causing the heat. This is also quite common after a device is dropped.
Larger Capacitors are generally the culprit and i would suggest if you have taken your phone apart, take it apart again and try to locate if a certain area of the board is getting burning hot vs other parts of the board that are not.
There are some great videos put together on youtube on how to detect a short on an iphone motherboard. Since you mention the heat, it is the first thing that pops to my mind.
Do disconnect the camera flex and back camera like @thegsmsoluion suggested though, as a fault in those components will stop an iphone 8 from booting.
FYI it will be common for the A11 chip (the cpu) to get hot while trying to boot as it is making all of its calculations and gets hot.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michal さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 39
今までの合計 2,503
