メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2018年9月21日に発売されました。モデル番号A1920, A2097, A2098, A2100。GSM もしくはCDMA / eSIM もしくはナノSIM / 64, 256, 512 GB / シルバー、ゴールド、スペースグレイ。(正しい発音は"iPhone 10 S.")
Waterproofness of iPhone after battery replacement?
Is the phone still water resistant after replacing the battery?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Something must be really wrong though if it needs a new battery this soon though...
さんによる 共有
@c9679 Yeah the battery on the XS seems to be pretty bad with deterioration. I have only had mine for ~6 months and its already down to ~92% health
さんによる 共有
@timothymcevoy that's bad u should really get it sorted under the warranty shouldnt need to be replacing the battery only a few months in... are u using good quality chargers and the genuine apple plug???
さんによる 共有
コメントを追加
4件の回答
ベストアンサー
You have to replace the speaker and there is no official guide on how to reinstall that properly. Also the water resistant adhesive is hard to reapply. I tried five times before getting it truly water resistant. I would not trust anyone on their first try.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
If you did it yourself then probably not as the adhesive is probably not as strong as it was at release. DO NOT trust it in the water. Its still risky even if apple did the repair as they will not replace any device for water damage even if it is within warranty and you kept the phone with in the water resistance limits. Also its water resistant not waterproof.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I would say, that event new iPhone is not really waterproof, sad but true.
If someone taked off old adhesive, and put new, original one on the frame, it should have some kind of protection, but if i open iph for customers i always say, that will never be safe to use it under water, even if im using original adhesives.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
You can do a pressure test with a barometer app, however it will not work for iPhone XS due to design differences.
さんによる 共有
コメントを追加
I replaced my iPhone battery through apple and when giving my iPhone a brief rinse, the Face ID broke. My phone is now going through a loop where I can't reset the phone without turning off find my and can't turn off find my without turning off stolen device protection. Stolen device protection can only be turned off with Face ID which does not work
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
luis amaral さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 7
過去 30 日: 24
今までの合計 14,338
