メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Is the top case changeable with a 2008-2010 top case?
Is the topcase from a mid 2012 MacBook Pro interchangeable with a 2008-2010 MacBook Pro topcase w/keyboard. It only comes with the keyboard, but I’m not sure if the backlit keyboard and ribbons for the speakers are compatible, thanks
I want to transfer a 2008-2010 topcase into a 2012 MacBook Pro, as my 2012 MacBook Pro has a damaged keyboard
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
If all you need is the aluminium topcase with keyboard, then the answer is yes, but stick to to 2009/2010 Pro series. There’s no 2008/2010 Pro, in 2008 and early 2009 there was just the A1278 Macbook Unibody that is not compatible at all. However, considered the difficulty involved in replacing the superdrive slot which holds different groudings for 2009/2010 and following models, evaluate carefully it it’s worth your while as the part may break in the process. I’d suggest you stick with i5/i7 replacement topcase for a smooth and troublefree work.
このアンサーは役に立ちましたか?
スコア 2
5 件のコメント:
I use a SuperDrive to HDD adapter. Will that work still? For some reason I forgot that A1278 didn’t come out until 2009
さんによる
Actually I realized that I don’t need the screws for the adapter as I don’t need to eject anything
さんによる
@coreycusick The adapter lays on the three housing screws which are the same for both models, no problem, just checked the two housings side by side. All you have to get replaced is the subwoofer glued to the topcase and attached to the right speaker.
さんによる
I finally found a top case that’s a decent price for the i series. I’ll just get that as it comes with the speaker assembly, thanks I just wasn’t really sure and couldn’t find a definitive answer
さんによる
@coreycusick You're welcome, happy fixing :)
さんによる
コメントを追加
回答を追加する
Corey Cusick さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 225
