メインコンテンツにスキップ
Guides and repair information for televisions made by ProScan.
18回答 すべてを表示
I have a Cracked tv LED Screen
I was playing my Xbox when the battery from the controller came loose and the corner of it, hit the screen of my Proscan plded-3274 Uk bi. There are horizontal lines Vertical lines. Where would I acquire a replacement LED screen? The TV is three years old so not under any warranty etc
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@samdamji it will be difficult to find a proper panel and it will most likely cost you more than a new TV would. Remove the back from your TV and take a look at the label on the panel. Use the model number on that to search for a replacement. The only other way would be to find a TV with the same panel as yours but that is otherwise broken. Then harvest the panel from that one. To replace the actual panel is not as bad as trying to find a replacement
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Sam さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 131
