What is the name of this component?
Please check the attached image, I have marked the component. I just need to know what is the name/model of this IC/Component. This burnt out, I can’t recognize its name/model. I want to replace by myself.
Thanks!
The photo is a bit blurry. Is there a map of this system board on its manufacturer’s website?
このアンサーは役に立ちましたか?
The component you circled can be either a diode or transistor. It has 3 leads and is the SOT-23 case style. Look at the top and get the code that should be written there. Search for that code like this on google: “SMD CODE xx” where xx is the code you read. That should help to determine the part.
Dan
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 181
Sure looks like a DIode. You do want to go ahead and try to post a couple of images that are less blurry and are closer to the component.
oldturkey03 さんによる
