メインコンテンツにスキップ
A budget flip phone by ALCATEL, also known as the OT-222.
6回答 すべてを表示
How do I enter Ford Sync pin number into Alcatel Flip Phone?
I’m trying to pair Alcatel One Touch Flip Phone with my Ford Sync but when I try to enter Sync pin number, it dials the number as if I’m making a phone call, How can I enter the pin number into my flip phone?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi @eelmas ,
You cannot “pair” your One Touch 222 phone with your Ford Sync, as the phone does not have Bluetooth connectivity.
It is not mentioned as a feature or setting in the phone’s user guide and as a further verification, in the specifications for the phone in this link it states Comms - Bluetooth - NO.
If you have a different model Alcatel Flip phone to the one you selected above, which does have Bluetooth connectivity, to pair the phone with Ford Sync, the Bluetooth feature needs to be enabled in the phone and then when Ford Sync appears in the phone’s Bluetooth “pairing list” you will be able to select it and then enter the code and the phone will be connected to the vehicle.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Lee Swallows さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 14
今までの合計 750
