メインコンテンツにスキップ
7.7" Android tablet released in February 2012. Samsung P6800
17回答 すべてを表示
My Tab not starting
Tab is not starting. Tried to charge many times but didnt got success. what is the reason for this and what should i do now.
Update (05/01/2019)
Six months back when I tried to charge my phone it was not charging. Just showing charging sign a rotating circle just like in a buffering video. Since then its not charging. I changed my charger also to find any problems if. But still now there is no progress. When I put it on charging tab gets bit heat up.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
Not nearly enough detail. Can you tell us a little more? Tell us what happened to it recently, any unusual things you notice about it etc.
さんによる
コメントを追加
1 件の回答
It may be that the power bottom has become loose from its hold due to shock, try taking it to an engineer or else if you have a toolskit download the video of how to unscrew the type of your phone on youtube to confirm what the problem is if it can be solved manually by you or by an expert.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Tried all things by myself.
There no such qualified person in my city.
I guess there is some software issue. Also went to service station, they also told that it's software issue.It would be good if you could provide some help.
さんによる
コメントを追加
回答を追加する
Himansh さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 167
