メインコンテンツにスキップ
2017年3月に発売されたiPadの第5世代。Wi-FiおよびLTEモデルで、32 GBおよび128 GBのストレージオプションがあります。 9.7インチRetinaディスプレイと64ビットA9プロセッサーを搭載しています。
174回答 すべてを表示
How difficult is the screen replacement
So I have an Ipad 5th Gen. Model A1822. My son tossed it across the room the other day, and the screen shattered. Gotta love 2 year olds right. Any who, I have some experience in dealing with electronics hardware, although I doubt anything as small as the hardware inside an Ipad. How difficult is it to replace a screen that has been shattered. I have read the guide, and watched videos, I did not see anything that I do not think I could do, but as often is the case, I worry that these guides and videos are making things look substantially easier than they are. So, is this something that the average joe can accomplish?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
No doubt guides are often making things easier than they are..replacing screen will take lots of time and patience especially for removing perfectly the old adhesive..that’s of the essence to get good and long lasting results and avoid digitizer issues. Besides that, the guide @sammyz linked for you includes all you have to know to do a great job :)
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Since you have experience in dealing with electronics, you are more than capable of replacing digitizer yourself, make sure you have the right tools to start with.
But first, take time to read this detailed guideline written by @refectio (scroll down to solution):
After doing my repairs (battery and screen) I have problems
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
iPad 5 Screen Digitizer
This kit says it comes with a new screen with adhesive strips, do I still need to buy better adhesive or are the ones that come with it of good quality?
さんによる
@dethnode Since this kit is sold by iFixit, I assume it will come with Tesa 61395 adhesive strips which is currently the best on the market, you don't need to buy any others.
さんによる
IMHO, if it doesn't say Tesa Tape, I would assume it is not. A quick call to iFixit Customer Support would clarify that however.
As for the OP's concern about guides making things look easy... I have to say that the guides are very good in general, especially those written by the iFixit staff. The only knock I would have is that they don't really cover re-assembly other than to say "reverse the steps". That works pretty well with iPhones but it is not the case with iPads (which is why I detailed my linked answer).
さんによる
コメントを追加
回答を追加する
john doe さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 25
今までの合計 689
