メインコンテンツにスキップ
iPad mini4のWi-Fi対応バージョンの修理ガイドです。モデル番号はA1538。2015年9月9日に発表されました。iPad mini4はiPad mini3の後続モデルです。
97回答 すべてを表示
iPad Mini 4 - Screen/Digitizer not seating correctly.
Hey all, New to the forums and new to working on a iPad Mini 4 reassembly. We had to replace a digitizer that was cracked with a brand new one, my only issue with it is trying to close the whole thing back up. Currently the issue persists near the bottom right hand corner of the screen but it can be the top right hand corner as well (Its usually on the right hand side.) My Theory is that the cables that attach from the digitizer and the board are not wanting to seat correctly and keeping the screen popped up. Attached with this post is a image of said iPad Mini 4, any help would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your theory is on point - cable is not folding in the right direction causing screen not to sit flush, you may also want to remove old adhesive and use Tesa 61395 tape, this is currently the best adhesive for screen repair.
Tesa 61395 Tape
@refectio wrote a great guideline for iPad screen repair, check out his answer in this post:
After doing my repairs (battery and screen) I have problems
Tesa 61395 Tapeの画像
製品
Tesa 61395 Tape
$5.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
For the Digitizer cabel itself, besides making sure its folded right, is there any other way to secure it say with kapton tape or double sided tape to make sure it just stays in place?
さんによる
@militiatech I don't believe taping is necessary if cable is properly folded and seated (it's a flex cable after all). That said, secure it with kapton tape or double sided adhesive won't do any harm and will hep securing it to some extent.
さんによる
コメントを追加
回答を追加する
Jacob さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 225
