メインコンテンツにスキップ
Repair guides and support for computer monitors produced by Samsung.
87回答 すべてを表示
P2770FH monitor power cycles (off, on) repeatedly (reboot/restart).
I am trying to get a Samsung P2770FH monitor working. The power supply was bad (about 5V output instead of the expected 14V) so I ordered a replacement. Now the monitor powers up, but under certain circumstances it will power off, then back on about every eight seconds. Depending on the signal, sometimes it will stay on longer, but usually power cycles within a minute.
Any common things I might want to check before I declare it dead? Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I hope you find a solution. I use a P2770 as a computer monitor on HDMI and have established that it power cycles only when specific (generally dark) colors are displayed on the screen. Very bizarre.
さんによる
コメントを追加
2件の回答
ベストアンサー
We ended up replacing one of the circuit boards, but I don’t recall which one. It was something we were able to order.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Was it an original power cable? Generic brands can be very glitchy to keep a monitor powered on.
One thing you can check is the voltage if you have a multimeter laying around. Otherwise the bad power supply could have shorten out the monitor as well.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I tested the original power supply and it was only putting out around 5V. I ordered a replacement (4A, exceeding the original's 3.5A) and the monitor powers on now. It just cycles off and back on after running a bit. Trying to play HDMI video through it, it will basically restart every 8 seconds. I find many references to issues like this online, but none had a solution, so I thought I'd try here. Lots of replacement boards available for this monitor on eBay if I knew what the likely cause was.
さんによる
コメントを追加
回答を追加する
Allen Huffman さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 29
今までの合計 1,128
