Can you replace save chip in Pokemon leafgrean cartridge
My Pokemon Leafgreen cart save chip is dead and if I could replace it or not and if possible it's cheaper than buying a new cart
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Not likely unless you know micro soldering. The innards are all soldered into the gameboy cartridge board. The memory chip is the black box on the right of the chip. Its also unlikely that you would find a chip replacement unless you can desolder it from another identical cartridge then solder that into the board of that cartridge. (very difficult) Essentially the answer is no. It would just be cheaper and easier to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 1,127
