メインコンテンツにスキップ
Repair guides and support for the laptop line of Acer's Aspire series for casual home and business use.
1191回答 すべてを表示
Laptop wont turn on only with cable after clean up intern
Hello you guys,
today i bought 2 laptops acers aspire E 17
since they where a little bit old and i want to at a ram memory and an ssd to make the pc go a little bit faster , my laptops wont turn on anymore.
first i opend 1 laptop to clean up inside. and after cleaning up and replace the logic board back in place, the laptop only starts up with an cable. i taught that i might damaged something first, like the battery.
now i opend the other laptop and place that battery in to th broken one to test, but it did not work.. i replaced the battery in the working one and now the both laptops have the same problems… what can this be???
is it like you are not able to take the battery out or what did i do wrong??
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If both laptops were working before they were opened, then they may have been damaged by electrostatic discharge (ESD). This could have occurred if you did not use an anti-static bracelet or anti-static gloves before servicing the laptops. ESD can cause microscopic, yet significant, damage to a motherboard.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I found it myself....
I never saw that before ever in my life,
There is a small button on the motherboard that needs to be pushed in before you can start your pc...
It only can be pushed in when the keyboard is replaced and screws are in the holes...
Feel so stopid
さんによる
コメントを追加
回答を追加する
glennjacobs さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 49
