メインコンテンツにスキップ
Released in 2014, identified by 11.6 inch screen, 2-in-1 convertible touchscreen laptop. Model number 11t-n000.
Laptop wont connect to internet
Laptop was working fine then it just stopped connecting online.  It says it is connected to our WIFI. We are running Microsoft Edge but Chrome doesn't work either.  Every website we try (Yahoo, Google) it keeps saying page not found. Other devices are running fine on the WIFI like out Ipads and our sons Laptop but this Laptop wont connect for some reason
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
Hi @erieschwab ,
If you have Win 10 installed in the laptop, go to Control Panel > Network and Sharing Centre > Troubleshoot problems and see if this resolves it for you.
To get to Control Panel, click on the Windows Start button and type CP in the search box. Click on the Control Panel desktop app option that appears.
さんによる
@erieschwab, Does your computer say it's connected, or does it show a caution symbol. Does it just not allow you to connect?
さんによる
It is Windows 10 I have tried the above but still same issue. It says its connected I tried the troubleshooter and it says everything is fine but I still can't load a webpage. When I try it says can't reach this page
さんによる
I can get to yahoo and google but thats it
さんによる
Hi @erieschwab ,
You may be getting the browser's cached pages for Yahoo and Google and not actually to the servers.
Try accessing the WiFi router address through your browser and see if you can talk to it.
さんによる
1以上のコメントを表示
コメントを追加
5件の回答
最も参考になった回答
If there is intermittent network connectivity, then the driver for your Network Interface Card may need to be updated. Please try the following:
1) Open Device Manager by typing devmgmt.msc in the Search box on your Taskbar and hitting Enter. The Device Manager utility window should appear.
2) Double-click the Network adapters entry on the list in Device Manager.
3) Right-click the name of your computer’s network adapter (for example, Realtek RTL8723BE 802.11b/g/n PCIe Adapter) and select Update driver from the pop-up menu.
4) Select the option for Windows to automatically search the Internet from the correct driver update. Windows should find and install the latest network driver for your system.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Tried didn't work same issue
さんによる
In that case , it may be a networking issue. Please do the following to refresh your computer's networking cache:
1) Type cmd.exe in the Start menu on the Taskbar at the bottom left of your screen.
2) Right-click the "Command Prrompt Desktop app" selection on the pop-up list and select "Run as administrator". A User Account Control dialog box should appear.
3) Select "Yes" in the User Account Control dialog box. A Command Prompt window should appear.
4) In the Command Prompt window, type the following exactly as shown:
ipconfig /release && ipconfig /renew && ipconfig /flushdns
5) Reboot the computer and try to connect to the Web again.
さんによる
I ran commands
Ipconfig/release
Ipconfig/renew
Ipconfig/flushdns
That seemed to work
Thank you everyone for your help
さんによる
コメントを追加
I’ve sometimes been succesfull by downloading the latest driver and then completely uninstalling the current driver. Running something like Ccleaner or AdvancedSystemCare helps to remove any ‘debris’.
SHUTDOWN laptop and re-boot then install downloaded driver.
You never know until you try it.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This worked for me. I dont know if it was a fluke but my wifi is working now. Go to network settings.
Right click on wifi adapter you want to use.
Click on properties.
Should say wifi properties , networking
Now where it says connect using…whatever adapter you want to work ……click on configure.
At the top click advanced.
Scroll all the way to the bottom under property and click wireless mode.
Hope it works for you. Like I said I dont know if it was a fluke.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Well you can try out this basic tip that can help you out :
Select the Start button > Settings > Network & Internet > Status. Under Change your network settings, select Network troubleshooter
And for more advanced tips you should check out this:https://wethegeek.com/reasons-why-window...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have had this problem & the Internet tech told me to move closer to the WiFi, like in the same room. That helped.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jason さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 1,723
