メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
5s and se the same
I have a iPhone se in poor condition with a broken screen. I also have a 5s in perfect condition that is iCloud locked.
What are my options to get one good phone. Can I transfer screen from 5s to the se, are they the same.
what do I need to take from se to put in 5s to stop iCloud lock, the logic board and home button?
Update (04/23/2019)
What about getting past the icloud lock on the 5s, anyway round it
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
Iphone 5S is iCloud locked so you can not use its logic board or any part which is associated with imei number. You can use battery, body cover if size are same and display. But for Display make sure screw position alignment are same for both screen otherwise it will not work. Better to use both iPhone use iPhone carrier unlock code for iPhone 5s.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Actually no, the battery is different between the SE and 5S, the only thing you can really use is the screen as they have the same connector. The battery and charging port have different connectors. Hope this helps.
さんによる
コメントを追加
If the 5S is locked and you want to restore the SE the one thing you CAN do is use the 5S’s screen on it. But the battery and charging port are different between the two models, if it’s just the screen your mainly looking for then your in luck. If it’s anything else major I don’t think anything else will work, that’s just from my experience, hope that helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If the screen is OEM, it will be pretty much fully compatible with the SE.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Aidan さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 79
