No power going to hot water tank - Solved
Why would my hot water tank not be getting power
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Use a multimeter and test the breaker box then the electrical wall outlet. If it is working, you probably have a loose or disconnected wire. Great care should be taken when looking or testing for it. I would unplug it and start testing for continuity of the input wires.
このアンサーは役に立ちましたか?
Thank you. It is wired right to the box
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 149
3 件のコメント
Gas or electric? Make & model number?
mayer さんによる
It is electric gsw I replaced the elements and thermostat but not getting power at all.
Laura さんによる
Thank you had someone in today I had to replace the box
Laura さんによる
