Print quality is light and with horizontal lines
Printing is light in all colors and has horizontal lines through all print
Most likely a Bad/Clogged print head. There should be a Clean Nozzle / Print Head option under Settings - Tools.
Try that, there should also be an option for align print head. If Neither of those work the print heads are too badly clogged or have failed completely. You can try cleaning the print heads out with isopropyl alcohol too. There is a good video Here.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 2,802
