メインコンテンツにスキップ
2.6GHzデュアルコアIntel Core i5プロセッサ(Turbo Boost使用時最大3.2GHz)、3MB共有L3キャッシュ
112回答 すべてを表示
Always needing to reset SMC + Fans running at full speed
For reference, I’ve done some troubleshooting and replaced DC-in at Unable to power up after it slept.
Latest steps to replicate issue, consistently:
  1. Failure to boot up post shutdown/sleep/close lid.
  2. Initiate force shut down by holding power button down.
  3. Power up with power button again. Fans will run at full speed. MacBook can be used this way but it runs at full speed constantly.
  4. Not wanting to use the computer this way, I force shut down by holding power button down. And then reset SMC by holding CTRL+OPT+SHIFT+POWER buttons down for 10 seconds.
  5. Power up with power button again. Fans run at normal speed. At this point if the MacBook goes back into state #1 (i.e. shutdown/sleep/close lid), I won’t be able to “power up” again. I’ll then continue with step #2.
Troubleshooting Summary:
1. Replaced DC-in, ok.
2. Wall socket checked out, ok.
3. Clean installation of latest OS, ok.
4. Charger using original one that came with my MacBook, ok.
Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
Hi
My guess would be there is some sensor that is malfunctioning in the computer
Download this free software called HWmonitor. This shows all the sensor temps in real time inside the laptop. Look for something that is unusual. something thats above 100c. Please report back
Thanks
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
There's HWMonitor by CPUID https://www.cpuid.com/softwares/hwmonito... but it doesn't have a Mac version. Do you have the name of the company that makes the HWMonitor you're referring to?
さんによる
Got it! At the time of the screenshot, my fans are running full speed.
Here is the screenshot: https://imgur.com/83SywOY
After the above screenshot, I went ahead to do the exact same steps mentioned in my initial post. I shut down the macbook, hold shift control option power to reset smc, and booted back up. This time there's a chime, and the fans are running normal speed, as expected!
Here's the screenshot now: https://imgur.com/7HjB7YF
さんによる
Any chance you had a chance to look at my screens?
さんによる
コメントを追加
Use mac fan control free
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JB Tan さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 24
過去 30 日: 88
今までの合計 4,675
