メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why is there no action from taptic engine after audio ic replacement?
So i recieved an iphone 7 that had the audio ic replaced. The customer said that it doesnt vibrate and people can not hear them as well as putting it on speaker changes nothing and sound still comes through the top speaker. I tested everything and they are correct about all of the issues. Also they stated that it will restart randomly for no reason. If any one could help me narrow down what's wrong with this board I would greatly appreciate it. Thank you all in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
The first thing to suspect is that the Audio IC repair didn’t go smoothly. If the “new” symptoms roughly correspond to the Audio IC repair, then I would inspect the workmanship and use that as a clue.
Assuming the Audio IC was properly replaced (with jumper on C12 at least) and there no obvious signs of missing, dislodged or bridged components, then I would start probing the the ARC circuit (taptic engine) and work my way from there.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
in my experience, if this occurs - reballing homer would help.
さんによる
コメントを追加
回答を追加する
Blaked89 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 518
