メインコンテンツにスキップ
2017年9月22日発売。モデル番号はA1864, A1897。GSM もしくはCDMA/容量は64もしくは256GB/仕上げはゴールド、シルバー、スペースグレイ。
678回答 すべてを表示
iPhone 8 plus touch and freezing issues after screen replacement
I replaced the screen on an iPhone 8 plus with iOS 12.0 installed, a few days later the touch became intermittent, sometimes it works great sometimes and won’t respond. I updated to iOS 12.2 hoping to resolve the issue but the issue only got worse. screen sometimes would just freeze, I tab the messages app and it won’t respond after a few tabs now it works, screen is too sensitive, all apps could start to wiggle as if I touched and held an app longer that 3-4 second when in reality I barely touched it. I re-installed the original cracked screen and now it completely frozen, I installed a brand new screen and its still frozen. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Hi Owen, thank you very much for your reply!
-I installed 2 new screens and it turned on frozen, I restarted the phone and it’s still frozen
-I went ahead and re-installed the original cracked screen it came in with, it turned on but it’s still frozen, I restarted the iphone and it’s still frozen.
- I now reversed the first screen replacement and i’m back to square one where screen works when it wants to.
I wonder if iOS 12.2 has something to do with it?
さんによる
It might. Try doing a full restore by going into dfu mode and restoring it via iTunes.
さんによる
コメントを追加
3件の回答
最も参考になった回答
Try replacing the screen. It’s probably just a faulty screen.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Have change the screen and the problem is still the same
My phone is hanging so badly
さんによる
@beauty64950 start a new post with your problem. More people will see it.
さんによる
コメントを追加
i found this on my search, try it
'''iPhone 8 Freezing'''
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
First remove the Home button flex and check that also cause such issues.This phone have 3d touch too this section makes such a problem.This will help you to solve that problem.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
info さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 12
今までの合計 1,564
