Screen no longer works
Works fine if I hook it to a monitor but the screen no longer turns on
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If it works when hooked to an external monitor then you either have a bad cable, cable connection to the LCD or a bad LCD. I would open it up and check the cable to make sure its connected and has no breaks. If the cable checks out you probably need a LCD. Good luck.
このアンサーは役に立ちましたか?
+ move the screen up and down and see if it flickers - thus indicating the data cable
This happens to my satellite too. Heres what I do to fix it.
1.Take Battery out
2.plug power in
3.while battery is still un-plugged and turned on pick up your laptop and tip it all the way sideways quickly. You should hear your fans boost and your screen will turn on.
4. replace battery while still turned on.
このアンサーは役に立ちましたか?
If this is working, aren't you essentially resetting the CMOS? If so then a new CMOS battery would solve this issue.
been using my toshiba satellite M305D without battery and directly AC plugged in. the last use was it was turned off but forgot to unplug from the ac. now the monitor is black. pls help. the turn on button lights up but no monitor, still black..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 4
今までの合計 3,547
1件のコメント
Thanks. Turns out when I split the case I did find a loose cable. Now it works great!
Marc さんによる
