メインコンテンツにスキップ
The Samsung Galaxy Tab A 10.1 is known by different models depending on the features. Regular model: SM-T580 (WiFi), SM-T585 (3G,4G/LTE and WiFi) released in May 2016 or S-Pen model: SM-P580 (WiFi), SM-P585 (3G,4G/LTE and WiFi) released in September 2016. It is a 10.1- inch tablet manufactured by Samsung Electronics and their new high-end “A” series.
108回答 すべてを表示
Touch Not responding unless your holding connection
Hello
I changed a Screen/Digitize on a Samsung Tab A. When push the home button it responds . When you try to tap the screen it won’t respond. When I press the ribbon connector to the chip it responses fully.
When you stop using it for more then a minute it take a while to response to the touch again.
I’ve tried taping the cable down to keep it secure and dosen’t help.
Any Help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I assume you mean that you replaced the touch screen on your Galaxy Tab A. Replacement of the touch screen can be tricky at best.
With the unit off, and preferably no battery, (for safety), unplug the cable, and clean all related connectors with rubbing alcohol, and a Q-Tip. Wait about 5 minutes for everything to air dry, then reassemble, and try again.
If this doesn’t work, then either the new screen is defective, or something was missed during reassembly. At this point, I’d suggest having a professional repair it for you.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I did that. It work when I hold the tab on the board in the back. I've tried three screens and two out of three work. I think the tab that holds it down isn't strong enough. Order new attachment and going to replace.
さんによる
Just sent it away to be check by another company and they are having the same issue.
さんによる
コメントを追加
回答を追加する
rcreaser さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 56
