How can I get my lap top out of a Vista repair/ restart loop
My Aspire 6530G lap top is stuck in a repair loop in Vista. Does anyone have a fix to get out of the loop?
You more than likely have a bad piece of ram or another bad component, try using heirens boot disk
このアンサーは役に立ちましたか?
A cycle of continuous restarts may be a sign of a driver problem that Windows Vista cannot circumvent. Luckily, there is something you can try:
This will make Windows Vista restore itself to the state it was in before the problem began. The system should boot normally from then on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 107
