My Whirlpool Cabrio platinum top load washer sounds/leaks/uL code
Washer works until spin then it starts to sound like a jet taking off. When it spin it’s also leaking from the bottom of the washer. Help?!!
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your washer is off balance or the load is unbalanced. If uL (unbalanced load) appears in display, the load is out of balance. ... Allow the washer to continue. If the dial is flashing and the washer has stopped, redistribute the load, close the lid, and press START/PAUSE.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 8
過去 30 日: 27
今までの合計 1,031
