Battery gauge reading 14 then drops to 12ish
Why at start up my battery gauge reads14 but after a few it drops to above 12ish
この質問は役に立ちましたか?
この質問は役に立ちましたか?
could be a worn battery as well as a failing alternator. Check the output of the alternator to verify that the gauge is true. Check this Ford ;-) guide 1997-2003 Ford F-150 Alternator Replacement on where to place the meter to confirm the output.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 11
今までの合計 907
1件のコメント
This is normal. They are designed to reduce alternator output when the battery is fully charged. This is to improve fuel mileage. This topic is described in the owners manual.
Doug さんによる
