Can you have both bluetooth and airport card in computer
if both card are installed will one
interfere with the other?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Apple has a couple of knowledge base articles that deal with the subject:
http://support.apple.com/kb/HT1365
http://support.apple.com/kb/TS1809
The second article specifically says that in the Macbook Air, using multiple Bluetooth devices can reduce the transfer rate of Airport networks. One of their suggestions is to use the 5 GHz 802.11 network instead of the 2.4 GHz network (an option I believe is only possible with the 802.11n Airport machines).
The first article mentions the possibility of Bluetooth/Airport interference without specifying computer models. But it offers the same kind of advice -- such as using the 5 GHz channel and reducing the number of active Bluetooth devices.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,562
