I need a replacement LCD touch screen is this even possible
I need a replacement screen for my mfc j6920dw is this possible as I cant find one anywhere
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @chrisw15 ,
I think that this is what you’re after.
The part number is LED448001 found in this printer parts list (scroll to p.17).
There may be other suppliers which suit you better. Just search online for LED448001 to get results
このアンサーは役に立ちましたか?
Check this page from printcopy.info to see all the parts you might need. The referenced part above appears to be the Touch Panel Assembly only, and there is an LCD also just in case your LCD is cracked too.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 7
過去 30 日: 25
今までの合計 5,522
2 件のコメント
Hi Chris
DO you have found a solution for your touch screen ?
I have the same problem, I need a replacement LCD touch screen
Thks
Jean Mich さんによる
Has anyone found a touch screen replacement yet?
andycobba さんによる
