メインコンテンツにスキップ
Repair guides and support information for televisions manufactured by RCA.
181回答 すべてを表示
Tv will power on and then power off
I've solved this before but unplugging it. Now I cannot get that solution to work. At one point I unplugged the hdmi and was able to get the cable channels to work. Powered it off, plugged in hdmi, powered devices back on, and the problem started again. How can I fix this?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
@amyrstiffler
if video sources other than your HDMI work t is most likely the main board that is the issue here. 3rd picture shows the main board. If it does not work with any input source you will have to measure the voltages from the power board to the main board.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
I was able to get it to recognize a different hdmi device, but then it powered off again.
さんによる
TRy something different than your HDMI. It still sounds like it's your main board just needing to checking other input sources
さんによる
コメントを追加
回答を追加する
Amy Stiffler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 55
