Repair guides and support for the 5th generation Honda Accord coupe, sedan, and wagon.
Rick King @rickking40307
評価: 1
投稿日: 2019年4月8日
I have a 96 Honda accord and the p1298 code is still showing after I changed the fuse box under the hood. How can I fix this problem?
この質問は役に立ちましたか?
oldturkey03 @oldturkey03
評価: 784.4千
1.1千
894
2.3千
Rick King of course you replaced your original fuse box with a known good one. You also checked to make sure that this is not caused by a bad PCM. If so then check on here on where to go next. Lots of checks in between
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 53
