メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
replaced screen with full assembly (digitizer, camera, earpiece)
I replaced the full assembly screen on iPhone 7plus and all is good except the front and rear camera are black but it does have all the icons and will navigate through each one but just black. The earpiece is also not working. What gives? Help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
So am I correct in assuming that everything was working 100% before you started this project?
As far as I am aware, there is, no relationship between the icons being available and/or damage to the hardware. Options within each application may be greyed out, but applications usually still open as usual even if there are hardware problems with the device.
So, you seem to be having an issue with the proxy flex (the flex at the top of the screen). The reason I say that is that the front camera and earpiece speaker are not working. They are both part of that flex assembly, so that is 2 parts not working on that flex, which may be a damaged flex, connector, logic board and/or components damaged around the connector.
Did you reinstall the brackets which hold the proxy flex components in place?
What is really strange is that you have a front and back camera issue. The main camera, connects to the board on its own. Make sure this is seated properly. I would also take the time to inspect the area around where the screen flex cable attachs. It is very very easy to dislodge a few components.
Did you disconnect the battery first before doing anything inside the phone?
このアンサーは役に立ちましたか?
スコア 1
10 件のコメント:
Ok so now I have noticed the earphones don’t work either.
さんによる
The earphones work just not in the phone since the screen replacement
さんによる
I am trying to help you and you have not responded to any of my questions?
さんによる
Sorry. I went out of town for my kids athletic teams. Your questions ? Yes everything was working prior to the install of the screen. Yes the brackets were reinstalled and disconnected the battery first. The earphones are not working either but the phone will charge. Very strange. I appreciate your help.
さんによる
This is a bit beyond my scope at this stage, seems you are having problems at both ends of the board now, which suggests it may be board level. We need to get some input from some of the more experienced techs here. ``Maybe @mayer or @minho can help.
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
Jackie Bell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 90
