メインコンテンツにスキップ
The DOSS SoundBox can be identified by its model number: DOSS SoundBox on the base between the feet of the speaker. Its a fourth generation bluetooth wireless audio player that was released in 2016.
Why is my speaker repeating a single sound of a busy phone line?
My speaker has suddenly began making a single sound every few seconds which sounds like a single busy signal on a phone. I have read the manual, turned off/on both speaker and phone without success.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 12
29 件のコメント
I'm having the same problem...
さんによる
I am also having this problem
さんによる
Same here. Anyone have an answer yet? I'd be sorry to let this speaker go but, it's really annoying.
さんによる
I’m also looking for a fix of this problem.
さんによる
Same problem here. I thought it was cuz I have a cheap speaker but if so many people are having the same issue...
さんによる
24件以上のコメントを表示
コメントを追加
13件の回答
ベストアンサー
It's low on battery. Plug it in!
このアンサーは役に立ちましたか?
スコア 13
7 件のコメント:
Yes, I figured it out early on. But you were right and it was very nice of you to take the time to answer.
さんによる
Mine is plugged in and I have a busy signal constantly
さんによる
My Journey exhibits the same problem. I wouldnt have thought 46% would be considered low. Why doesnt it just nag me to turn on battery saver?
さんによる
cjwidomski It may be pugged into a "low" power usb port. Change to a more direct charging port. (This happened to me when I plugged it into a "monitor usb" port rather than a direct power port.)
さんによる
The exact same thing was happening to me and like the others it just needed to be plugged in. I plugged it in and just kept using it until it was full
さんによる
2件以上のコメントを表示
コメントを追加
Mine just needed to be charged. I think the busy signal tells you it needs a charge. We all get hungry!
このアンサーは役に立ちましたか?
スコア 5
2 件のコメント:
Luv your comment
さんによる
Thank you whoever took the time to post this answer....appreciate your kindness !!!
さんによる
コメントを追加
The best answer I have for you is that your rechargeable battery needs to be replaced inside the unit. It probably is charging at a very low rate and even though it still powers the unit, it needs to be changed out.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
So where is the compartment to replace battery
さんによる
you have to open it up. Carefully remove the front grill and you'll see the screws.
さんによる
コメントを追加
There may be a warranty on it. You can contact the seller directly about warranty information on Amazon.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
There is no one to call
さんによる
I have the same issue, a High Serria speaker that I got at a convention. Plugging it into a good wall USB charger, it shows three solid lights and one flashing when charging, so it is showing me it has a charge. The two "busy" beep sounds will not stop if it is charging or not. Not until I turn the unit off does the busy signals stop.
さんによる
コメントを追加
I replaced the lithium batteries myself by soldering new ones in place of the old and it’s working properly now. Batteries are 3.7 volt rechargables. Can get online or at specialty stores.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
The sound of a busy signal on my new speaker meant it needed charging. I charged it and the busy signal stopped.
さんによる
Mines doing the same but its coming out of the phones call speaker and I have nothing open
さんによる
コメントを追加
Mine ended up after I replace the batteries being the battery charger built-in to the circuitboard so now I swap the batteries from the one functioning speaker to the other it’s a bit of a pain but it works
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Charge the battery in your speaker. The busy sound means it too low in power.
Update (09/19/2020)
You need to charge up the battery. The signal is telling you it is too low.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I thought it was supposed to be solar powered, so why isn’t it keeping charged?
さんによる
コメントを追加
After plugging the speaker If the charge light does not come on the internal charge circuit Has failed. I realized this after replacing the batteries which are soldered in and cost 25.00.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I see that almost everyone is saying the phone is low on battery and needs to be charged. However, my phone does it when it's fully charged.
さんによる
コメントを追加
It’s telling you that your battery is going to run out soon.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Mine beeps at 20% power or less, interrupting my movie or music every few seconds. I have a “Curve” brand of earphones that I bought in a retail store.
There should be a setting to cancel that sound and simply enjoy listening to the movie or song until the battery runs out. But there is no setting.
I would advise against buying this speaker.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same problem. Someone above mentioned that they “replaced the battery”?? . . . But mine charges via USB. ???
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
My LG Stylo was doing the same but one I activated Device Pulse it has stopped. I knew it was not the battery because my phone charges just fine & keeps a good chargeall day.
さんによる
My issue is that when my Bluetooth speaker is connected to my phone and i receive a phone call it keeps on repeating the same phone number everytime after the call what to do please
さんによる
コメントを追加
So the general consensus is that this portable speaker starts making this near constant busy signal when it drops just below half charge?
So in other words, It's defective...?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
most of the answers state it needs charging.what a stupid answer.im sure 99.9% of users would know this!! what do you do when the busy signal continues when it is fully charged??
さんによる
You pray to god and say hey what’s up with my WiFi speaker it’s never ever done this before and I know there’s nothing wrong can you give a brother a hand please
さんによる
コメントを追加
Como posso comprar os auto falante da DOSS soundbox ou cód Moro em São Paulo cidade de Cotia
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Judith さん、ありがとうございました!
統計データ:
過去 24時間: 23
過去 7 日: 121
過去 30 日: 564
今までの合計 62,065
