メインコンテンツにスキップ
ヒューレットパッカード(HP)は1993年よりパーソナルラップトップコンピューターの製造を開始しました。
HP 430 G6 Stretch Release Tape
Hello everyone,
my name is Rat and I work as a computertechnician. I recently ran into a couple of devices with lcd panel issues. To my surprise there were no screws that held the lcd panel in place.
In stead HP opted to use some sort of “stretch release tape”. Upon removal, I noticed that it wouldn’t be possible to reuse the tape, so I’m in a bit of a problem here. I tried finding the same kind of tape online, but nothing came quite close to what I needed.
I then stumbled upon this video by 3M: https://www.youtube.com/watch?v=xf84aWV0...
This is exactly the sort of tape I would need to do future screen replacements on such devices that have no screws to attach the LCD panel. However, I cannot find a single webshop or website with such tape on offer.
Any kind of help resolvin this matter will be greatly appreciated.
Kind regards,
Ratje
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
I'm encountering this also on an HP laptop screen. I have YARDS of very strong double sided carpet tape. Why not use that? Available at ANY hardware store, dirt cheap, and if you have to remove the screen again it will only be because it's already BROKEN, so what difference does it make if you basically rip it to pieces in that process, assuming that ever even becomes necessary again.
さんによる
I have to remove working screen from broken lid, do do not want to break the screen!
さんによる
if you cant get the stretch tape, get some thin 3m vhb . a couple of bits of that and the screen wont go anywhere. if the screen breaks, you just rip it out. its not ideal, but it does work. do be very careful when you fit the screen though, as if you dont get it right, you will have to ruin the screen to get it out....you may get away with lots of isopropyl to dissolve the glue though, worth a try.
さんによる
コメントを追加
4件の回答
最も参考になった回答
Hi @ratvanzichem ,
Have you tried contacting 3M in your location and asking who distributes their Stretch Release Tape 6657-150 or where it may be available from?
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I couldn’t find that tape either so i went and bought the 60 pack of Command Poster Strips for under $10. I put one on each corner behind the monitor and i now feel like the reason I couldn't find that 6657-150 tape from anywhere else, is because it is the command tape and its 3Ms secret to keeping us from buying it cheaper in bulk :O
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hello. I'm SeungTaek, Han of PROFINECHEM Co. in South Korea.
We recently developed a product similar to 3M tape. Are you trying to apply it to an HP product?
Please provide your email address and we'll send you the Technical Data Sheet.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
Hi Seung Taek, I am after a product that you describe. Yes it is for an HP product. I only need two strips. I am in New Zealand. Cheers.
さんによる
Hello I am also interested in your product my email is mrmontes89@gmail.com
さんによる
Is this available somewhere in the US? I also need some strips.
さんによる
Considering I didn't actually view the removal video about the release tape, I simply used brute force to remove the lcd panel and release tape. Since my screen is cracked anyway it didn't matter if I damaged the screen. So my question is what difference does it make what tape you use to restick it back in.? As long as it is double sided and holds the screen to the back and the side of the screen to hinge then no problem! The only problem would be removing it gain to send it back under warranty if it failed.
さんによる
It matters because the genuine tape simply needs to be pulled using the tabs provided and it stretches into a string and simply peels off from behind the screen. It is a 1 minute job to release and leaves no residue. Trying to obtain the replacement strips seems to be impossible though!
さんによる
3件以上のコメントを表示
コメントを追加
Go to LaptopScreen.com and see the LCD screen replacement for HP 14-DK1003DX. Scroll to the bottom of the page and you’ll find LCD Mounting Adhesive (for tab-less screens) which is pre-cut sections of stretch to release tape. The only other place I found is Adhesive Tapes Australia which sells Tesa double sided, bond & detach tape in 50 meter lengths (www.adhesivetapes.com.au/product/tesa-double-sided-bond-detach-tape).
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Rat Van Zichem さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 29
今までの合計 5,805
