engine reving up and down while driving at a high speed
why is the engine reving up and down and the rpm’s going up and down while driving at a high speed?
If it has an automatic transmission, the ‘kickdown’ probably needs adjusting. If you say that to your mechanic and describe you symptoms, he should know what you mean.
And here’s an article explaining kickdown if you’re interested.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 10
今までの合計 1,546
When does it happen exactly? Or is it completely random? While in cruise control? Going uphill or downhill? More details!
Craig Lloyd さんによる
When RPM's go up and down does it feel like the car losses power? Could this be a transmission that's going out? Is it stick or automatic?
iHeartMacs さんによる
