What is the size of the 11 screws at the base?
I need to know the size of the 11 screws for the back cover so i can order replacement
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
According to the service manual (p.32, Removal of base cover) the 11 screws are M2 × 3.5 mm, Phillips-head, nylok-coated.
Good hardware stores should have M2 x 3.5mm screws, maybe not nylok coated though
You could also search online using the part number for the screw pack (5S10K38946) for the Ideapad, but you may get other different screws as well as the 11 screws that you want.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 895
