メインコンテンツにスキップ
The Pontiac Grand Am is a mid-size size (and later compact) car produced by Pontiac. The 1999-2005 generation is the final generation of the Pontiac Grand Am.
142回答 すべてを表示
no power to my fuel pump
Have no power to my fuel pump my 2000 Pontiac Grand am but it does have power to hook the fuel pump up to just a battery
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
選択されたソリューション
angiewheeler705  check in the fuse box under the hood. There is a fuel pump relay. Use a test light to see if you have power to that. #18 in the picture
We would need to know the engine size of your Grand Am so we can check the wiring diagram as well. Let us know what you find.
このアンサーは役に立ちましたか?
スコア 5
4 件のコメント:
When you take the relay out, you should have power on 2 of the contacts in the fuse box, one is the control side where the computer tells it what to do and the other is the load side which actually jumps power to the pump, you can also hot wire the load side to see if the pump works but BE SURE of the pins. Is there an identical relay to swap, this will test the relay switch inside, if it works like normal, buy new relay. ONCE you have wire diagram, more help to be given.
さんによる
I have a 2004 grand am 2.2 no power to fuel pump and I just replaced pump
さんによる
2002 2.2liter Pontiac grand prix
さんによる
I'm having the same problem. Ony way I can get power to fuel pump is to jump the relay. Where to from there?
さんによる
コメントを追加
回答を追加する
angiewheeler705 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 36
過去 30 日: 139
今までの合計 3,858
