メインコンテンツにスキップ
Wi-Fi版iPad Mini 2の修理ガイド。2013年10月22日発表、11月12日発売。iPad mini 2はiPad mini Retinaディスプレイモデルとして知られ、iPad Airのすべてのピクセルを7.9インチに小型化しました。
220回答 すべてを表示
recently replaced digitizer issuse
So, i recently replaced a digitizer not from ifixit.
and it worked for a few seconds but stopped working completley after a few good seconds home button was not working too. i opened up the mini again and inspected it. No issuses whatsoever and put it back on. digitizer and home button is not working at all. should i sell it for parts?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Did you have the same issue before replacing the digitizer? I suspect that replacement digitizer is defective, try another known working digitizer to confirm.
If issue persists, then you need someone with micro-soldering experience to fix as this is board related.
One thing I want to point out that the Mini/Mini 2 replacement digitizers are notorious for ghost touching (iPad activates itself erratically), make sure you cover the bottom strip near home button with Kapton or any ESD tape.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
the old digitizer has the ribbon cable ripped out making it useless
さんによる
コメントを追加
Sins you didn’t buy it from ifixit i am assuming the quality was bad and thats why this happend. Do you still have the old screnn if you do try to see if it turns on. Is it recognized by iTunes?
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
the old screen is done beacuse i got it the ipad for free and the ribbon cable is gone for the old digitizer
さんによる
it is recognised my itunes
さんによる
Okay so just buy a new one from here and it should work
さんによる
コメントを追加
回答を追加する
Zander Castillon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 57
