メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
After succecfull screen replacement, iPhone is not working.
Installed new screen, instead of broken on iphone 7. It was working for two days, suddenly it started rebooting and now it is not working at all. Itunes dont see it, pushin vibration button there is no vibration. What it could be?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You might want to open the phone again to double-check your connectors (battery, LCD, lightning dock connector, front camera flex). How was this phone damaged originally? Drop damage? Liquid damage? Run over with your car? Depending on what happened, you might have more damage to repair than just your damaged screen.
I’d start with simply checking your connections. Open the phone and disconnect the battery first. Carefully lift the connectors and reseat them to ensure they all have a solid connection to the logic board.
Without additional information or some diagnostic tools on your part, it’s difficult to say what the problem could be. Since you have already opened the phone to perform the screen replacement, the likely place to start troubleshooting is to go back and check your work.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Before I replaced screen, phone fell out of pocket and glass was broken, but the screen was working perfectly.
After the problem appeared (phone is not working), I dissasembled it again and checked all the connectors, but it did not solve the problem. Later, I put old screen with broken glass, it did not help again...
さんによる
コメントを追加
回答を追加する
d1m4chas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 34
