メインコンテンツにスキップ
Repair information, service manuals, and troubleshooting help for refrigerators manufactured by LG Electronics.
120回答 すべてを表示
Why is my LG French Door Refrigerator not cooling/freezing
My LG French Door Refrigerator (LFX31925ST), wont coool or freeze the refrigerator is at around 60 degrees and the freezer is at around 40 degrees for over 24 hours, after I cleaned the coils in the back and unplugged the it for 30 seconds to reset it. Please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Use a multimeter and check these first: Please give us your model number.
Cause 1
Condenser Fan Motor
The condenser fan motor draws air though the condenser coils and over the compressor. If the condenser fan motor is not working properly, the refrigerator won’t cool properly. To determine if the fan motor is defective, first check the fan blade for obstructions. Next, try turning the fan motor blade by hand. If the blade does not spin freely, replace the condenser fan motor. If no obstructions are present and the fan blade spins freely, use a multimeter to test the fan motor for continuity. If the condenser fan motor does not have continuity, replace it.
Cause 2
Evaporator Fan Motor
The evaporator fan motor draws air over the evaporator (cooling) coils and circulates it throughout the refrigerator and freezer compartments. Some refrigerators have more than one evaporator fan motor. On refrigerators with only one evaporator, the evaporator is located in the freezer compartment. If the evaporator fan is not working, it will not circulate the cold air to the refrigerator compartment. If this occurs, the freezer may still get cold, while the refrigerator will not get cold. To determine if the evaporator fan motor is defective, try turning the fan blade by hand. If the fan blade does not turn freely, replace the fan motor. Additionally, if the motor is unusually noisy, replace it. Finally, if the motor does not run at all, use a multimeter to test the motor windings for continuity. If the windings do not have continuity, replace the evaporator fan motor.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you very much for the reply, i’ll give this a try when I get home this afternoon. I have an LG French Door Refrigerator MODEL #LFX31925ST
さんによる
コメントを追加
回答を追加する
Rob さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 10
過去 30 日: 19
今までの合計 334
