Hp omni 10 LCD connector flex panel to mother Board damaged repair?
Lcd connector cable is damaged due to which lcd is not working or some times working bad ,double screen and color/blac white lines on one side of screen.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @sghugharwal ,
Here is the part number for the LCD flex cable - 739817-001.
If you search online using the part number only in the search box of your browser, you’ll get results for suppliers of the part.
The part number is found on p.40 of the service manual for the tablet.
If you need a new LCD assembly, the part number - 739812-001, is found on p.13
このアンサーは役に立ちましたか?
So just replace you LCD.
このアンサーは役に立ちましたか?
Can't find lcd , actually problem is in connection flex cable , which connects lcd and mother board its an 2 ended cable(ie it is not soldered on any sides either motherboard or lcd ) both have slots for this cable to inter connection.
So your saying that the part of the logic board that connects to the LCD is broken?
YES that part is broken now found that part but sellers are asking ~100$ too expensive to consider buying for this old tablet. if u find it anywhere else please let me know .LCD flex cable - 739817-001. this is the part number . thank you.
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 279
1件のコメント
[image|1717306] this is one end of cable on motherboard side ,other side is similar but alittle wider , its damaged as we can see it in oicture
Siddharth さんによる
