MacBook Pro only turns on when I connect the charger without battery
I was on vacation and when i came back the macbook wouldn’t start.
I removed the battery and connected the charger and it turned on. But the display is nearly black although i can see something if i try very hard. keyboard and trackpad and power button are not working. The only way i can use it is by connecting an external display, mouse and keyboard and by plugging and un-plugging the power connector.
The light on the connector is green and the battery charges.
I can get the display to work (not the keyboard and trackpad) if i hold the power button and plug the charger at the same time. the fan will run on high speed and the power button now works too. but as soon as i do a SMC reset i’m back at square 1.
Also when using the mac as a desktop it seems sluggish.
tried:
1- smc reset
2- pram
3- nvram
4- repair disk
5- mac hardware test
6- tried with another charger that i know to be working
7- even if the battery charges if a remove the power cable it shuts down.
nothing worked.
Would appreciate if anyone could give me some input on this problem.
この質問は役に立ちましたか?
