メインコンテンツにスキップ
The Samsung Galaxy A3 (2017) is a mid-range smartphone in the Galaxy A series. It was unveiled by Samsung in January 2017 together with the Samsung Galaxy A5 (2017) and A7 (2017). [summary_image|1224313]
16回答 すべてを表示
Swap microphone with speakerphone mic?
Hi there. I’ve got a 2017 A3 whose usb port i was replacing,but unfortunately spilled flux to the mic hole nearby and i think i broke the mic. Can i swap this over with the speakerphone mic,instead of waiting for a new one?
Also,how resistant are these mics to heat? Could heat have broken it and not the flux? (didnt push heat through the hole,though. It had kapton on that side. Too bad the flux went through..)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
frizstyler  both Mic’s have the same part number 3003-001233 so they are compatible. Unlikely this is from the heat but most likely shorted out.
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
thanks mate.
I’m not asking whether the mic’s are the same,i’m asking if it’s ok to remove the speakerphone mic and place it there.
さんによる
Since they are the same mics you can just place it there.
さんによる
but the speakerphone will have no mic. will the device work properly? thats what im asking..
さんによる
frizstyler that will depend on your phone's firmware and if it does a self test on the mic. Most likely is that it will work. Eventually you would want to go ahead and replace the mic.
さんによる
コメントを追加
ok i swapped them over and it works! Hmm.. dont know whether this affects the stereo sound of video though.. and noise cancelling must no longer be working…
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
frizstyler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 352
