メインコンテンツにスキップ
Repair guides and support for Nextbook tablets.
392回答 すべてを表示
Plugged in charger and red light comes, but...
I plugged in my charger to my Nextbook tablet. Red light came on but changed to orange within seconds. Tablet will not turn on at all and says 2% battery life. How do I fix this without taking it apart?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
Based off of the information given, my best guess is that this is a battery issue. Especially if the device is a few years old. If that is the case, your only option is to open it up to replace the battery. There are a few trouble shooting steps you can take. First, try a different power brick and charging cord if you can. Second, see if you can perform a hard restart on the device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
i have the same issue i found that if you plug a variable voltage charger into it and very slowly charge it that it works hope this helps.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
camden0715 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 6
今までの合計 715
